Bulk loading soft-typed end items
Level 1
I am trying to bulk load a "soft typed" end item but I am getting the following error: -
Create Part Failed (301002022 1.<iteration>,YGB): Unable to create object class wt.part.WTPart.
Nested exception is: wt.util.WTPropertyVetoException: The value of "Type Definition Reference" cannot be set to null, since it is a "required" attribute.
Loader method wt.part.LoadPart.beginCreateWTPart reported a failure
No objects were imported due to the error.
Check method server output for successful completion of all loads.
I am using wt.part.LoadPart.beginCreateWTPart but should I be using wt.part.LoadPart.createProduct instead?
I thought a bit more.....maybe it is your type definition? You may be
able to do what you tried, but how did you define typedef?
BeginWTPart~create~wt.part.LoadPart.beginCreateWTPart~partName~partNumbe
r~type~source~folder~lifecycle~view~teamTemplate~lifecyclestate~typedef~
version~iteration
EndWTPart~create~wt.part.LoadPart.endCreateWTPart~publishFlag~parentCont
ainerPath
Also I attached an example of a part load.
Kevin J. Hanmann
Solution Master Architect
5417 Sports Club Run
Suffolk, VA 23435
781-370-5088 office
919-656-4255 mobile
781-707-0498 fax
RE: Bulk loading soft-typed end items
Hi Sam,
I am also facing same error, while crating new soft-type WTPart using java class. Can you please let me know how can I resolve this issue?
Avinash
In Reply to Sam Dickinson:
