Windchill 11.1 MO20 CPS29
Existing Environment:
I have a Test environment cloned from Production but I have not configured Vault while rehosting due to high Storage space. Now, I have created a new vault and configured to Test.
Issue:
I have a BOM in Test Environment with 1500 WT. Parts where need the representation to visualize in Thumbnail. How do I load the thumbnail in bulk.?
Hi @Shashwath
Is it problem to take the CAD from source system and check in all data to new one?
It is easiest way to do so.
PetrH
Hi @Shashwath
If you have a CAD structure just run a visualization on that CAD models.. The thumbnails will be generated.
PetrH
Hello @HelesicPetr
But as Vault does not contain any files. this CAD structure cannot generate any thumbnail at all.
Hi @Shashwath
PetrH
