I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.2
We implemented BOM view Business rules for WTParts which is working . we trying to configure the same for EPMDocuments , BOM CAD rules for validate the that all child components are in released state but which is not working . need to know if there any preference for CAD documents .
Hi @LS_10690167
Hard to say what is wrong in your case.
Give an example how you define the rules for wtp and cad
any screen for better imagination is helpful
PetrH
Hi @HelesicPetr
Thanks for replay .
Requirement-When the Cad Assembly going through the ECN process we should validate all child parts are in release state if not it should throw the error.
I have implemented business rules for Cad Documents BOM release Rule as per PTC help suggests here is the link
and also am sharing the business rule with you .
Regards
Lakshmisha s
Hello
You can try usig the FELCO Solutions Object Validator that has more business rules options than PTC out of the box. The object validator works within all the Change Objects Wizards, Promotion Requests Wizard, workflows and a right mouse click. The business rule that you are having issues with is in the Object Validator. I have provided a link for you to review below if you are interested.
https://www.felcosolutions.com/objectvalidator
