how to configure the CAD Agent in Windchill Cluster environment ( ie 4- Identical node)
please share ur inputs.
Hi Gangs !
I will try to provide an overview on the installation ,
CAD Worker installations/Box is a stand-alone installation (runs Pro-E / Creo instance in silent mode) may be in a independent server.The details of the CAD Server are captured in Agent.ini in the MasterNode. (BGMS Server) ..
You need to install the Pro_e or Creo Version on the CAD box first and then install the Product View Adapter (to support the Publihsing you are gonna do) & configure the Adapter to the ProE ..
You may configure the Worker agent Admin via Site Tab which will update your agent.ini file.
{P.S : Pls remember Foreground agent.ini need not have info on the CAD Servers . BG Node'e .ini is the file needed,}
The detailed process is mention in guide as well
