CAD Worker NX "save of file" failed error disconnects NX from WGM
Dobi
If any of you have running systems with NX (we're on 2007) in Windchill (WC12.0.2.8 and WGM 12.1.1.0), have you run into this error on the CAD worker?
What it seems to result in is disconnecting NX from the WGM and then subsequent jobs fail with the same signature when in fact there is no error.
The first failure that occurs is genuine (something off with the drawing). Right after that, there's an entry in the NX .syslog file saying something like "unloading .ugadaptor dll for WGM". And then the worker for NX is down until the application if removed from Application Management and re-added.
Are there some wgmclient.ini options for ignoring regen or attribute errors like there are for Creo? Is there a graceful exist to this error that doesn't take the whole worker instance down for all the subsequent jobs?
0 REPLIES 0
