CAD Worker - Publising Issue
Amirtharaj_K
Hi Everyone,
I am currently working with SolidWorks and Inventor, both of which are successfully integrated with Windchill. The attributes are correctly mapped in the EPM Documents and are also visible within the respective CAD tools.
However, I’ve encountered an issue where these attributes are not appearing in Creo View when viewing the PVZ files, even though they are present in the native files.
Has anyone else experienced a similar issue? If so, I would appreciate any guidance or suggestions on how to resolve this.
AJ
TomU
(To:Amirtharaj_K)
Have you installed Workgroup Manager on the worker machine? I believe with non-Creo workers you need WGM installed for attribute sync.
@jbailey Thanks for the response,
How can we sync the attributes in WGM or Creo View Adapter?
Aj
TomU
(To:Amirtharaj_K)
This article explains how to set this up:  https://www.ptc.com/en/support/article/CS48758
Amirtharaj_K
(To:TomU)
@TomU Thanks for the Article, now I can able to receive the attributes.
AJ
