HI all,
Is there a way to automatically create reference designators for a part with QTY>1, in the WTPart structure?
Iam checking in a CReo 2.0 assembly to windchill , WTParts are created as per the CAD structure, but the reference designators are missing in the WTPart (parent part).
I looked up the preferences and there seems to be none.
Iam using Windchill 10.2 and Creo 2.0
Thanks & Regards
Hari
This definitely helps!!
Thanks a ton!
Best regards
Hari Varadharajan
Thanks a ton!
Best regards
Hari Varadharajan
