CAD worker gives "WWGM ERROR: Error from UWGM-Registration with server failed" error
Version: Windchill 13.0
Use Case: We upgraded the dev server from WC12 to WC13. I prepared a new CAD worker with clean CAD/WGM/Adapter installations. It connects fine, tests fine (when worker in Worker Agent is in offline mode) but on a publish job gives a "WWGM ERROR: Error from UWGM-Registration with server failed: The server couldn't be found at the given location" error. Why? The dev environment was a new VM with a clean install and then migrated over our production settings. Is there some dangling pointer to the prod server that's messing with this?
Description:
