Hello Shyam,
I did a deeper review. It appears you added new lines to incorrect steps...
1. I would suggest you Fix the Defects associated with an Individual Step
THEN
2. Make Changes that Might Renumber the Steps.... Or Steps that had no number.
The Defect Log is tied to the Numbers as they appear in the 3/31 Printout or Electronic Copy. Some of the Corrections for 4/27 may be off a step but not 100% sure.
Also I can not reiterate that it might be bset to start with the Good 3/31 Version to add the Defects Against.
Brian Sullivan
