CADSYNCHRONIZED
rleir
CADSYNCHRONIZED
Team
I don't see a CADSYNCHRONIZED field in QueryBuilder PartUsage WTPartUsageLink.
Why? Do I need to install something?
The field should exist according to:
'Table Name: WTPartUsageLink has column called “CADSYNCHRONIZED” with values “yes|no”'
https://community.ptc.com/t5/Windchill/report-for-CAD-to-Part-structure-comparison/m-p/913189
and
https://www.ptc.com/en/support/article/CS332588
'Attributes; localId, ufid, externalTypeId, traceCode, lineNumber, cadSynchronized, componentId'
https://support.ptc.com/help/windchill/r12.1.2.0/en/index.html#page/Windchill_Help_Center/customization/WCCG_PLM_AP242_WTPartUsageLink.html
You might find this helpful. This is a report template I created that returns WTPart structures that have not been "built". Just keep in mind that if a WTPart structure is updated after the CAD check in, it will get flagged as not "built" (even if it was built during the initial check in). I have a data monitor that runs weekly to find issues and address.
Another thing to keep in mind is that certain errors in the CAD models (such as failed placements) will prevent Windchill from doing the Build, even if the engineer has it set to build on check in.
The key criteria is EPMBuild History.Status = 1.
I have Administrative Domain.Name like "default" to help eliminate returning items in Workspaces.
I also am omitting Obsolete parts
The subselect is just to get latest revisions:
joe_morton_3-1704745179597.pngjoe_morton_4-1704745188664.pngjoe_morton_5-1704745200720.png
Hope that's helpful!
7 REPLIES 7
GrahamV
(To:rleir)
It should appear as 'Build Status' in Query Builder.
rleir
(To:GrahamV)
Here are the options for  PartUsage.Build Status :
but PartUsage does not relate to CADs?
In EPMBuildRule I have no Build Status field. There is a field 'Cad Representation Role' which seems to always be yes. I is that the field for CADSYNCHRONIZED ?
GrahamV
(To:rleir)
Build Status is an indication of whether a WTPartUsageLink was built from CAD (or vice versa, you can build CAD structures from WTParts), it's useful for identifying parts that have been manually structured. Sounds like it's not what you're after though, what are you trying to achieve?
rleir
(To:GrahamV)
Thanks Graham.
I want an informal way to know which engineers are not checking in their CAD with 'build-part-structure'. And to know which 'gear' assemblies probably need to be corrected.
rleir
(To:joe_morton)
Very helpful, thanks!
What do you mean by failed placements’ (other than perhaps parts which are not nested in parent assemblies correctly)?
By failed placements, I mean a mate that has failed. A common case is when parts are mated in the assembly, but then later the part geometry is changed so that the mates are no longer valid. If the assembly is checked in to Windchill with those invalid mate conditions, Windchill won't do the Build.
