CARDINALITY hit cause windchill to be very slow - Windchill official bug
TB_10966080
SELECT 'wt.doc.WTDocument',A0.administrativeLockIsNull,A0.typeadministrativeLock,A0.blob$entrySetadHocAcl,A0.checkoutInfoIsNull,A0.statecheckoutInfo,A0.classnamekeycontainerReferen,A0.idA3containerReference,A0.department,A0.description,A0.docType,A0.classnamekeydomainRef,A0.idA3domainRef,A0.entrySetadHocAcl,A0.eventSet,A0.classnamekeyA2folderingInfo,A0.idA3A2folderingInfo,A0.classnamekeyB2folderingInfo,A0.idA3B2folderingInfo,A0.classnamekeyformat,A0.idA3format,A0.hasHangingChange,A0.hasPendingChange,A0.hasResultingChange,A0.hasVariance,A0.indexersindexerSet,A0.inheritedDomain,A0.iopStateinteropInfo,A0.stateinteropInfo,A0.branchIditerationInfo,A0.classnamekeyD2iterationInfo,A0.idA3D2iterationInfo,A0.classnamekeyE2iterationInfo,A0.idA3E2iterationInfo,A0.iterationIdA2iterationInfo,A0.latestiterationInfo,A0.classnamekeyB2iterationInfo,A0.idA3B2iterationInfo,A0.noteiterationInfo,A0.classnamekeyC2iterationInfo,A0.idA3C2iterationInfo,A0.stateiterationInfo,TO_CHAR(A0.datelock,'dd mm yyyy hh24:mi:ss'),A0.classnamekeyA2lock,A0.idA3A2lock,A0.notelock,A0.classnamekeymasterReference,A0.idA3masterReference,A0.oneOffVersionIdA2oneOffVersi,A0.classnamekeyA2ownership,A0.idA3A2ownership,A0.securityLabels,A0.atGatestate,A0.classnamekeyA2state,A0.idA3A2state,A0.statestate,A0.teamIdIsNull,A0.classnamekeyteamId,A0.idA3teamId,A0.teamTemplateIdIsNull,A0.classnamekeyteamTemplateId,A0.idA3teamTemplateId,A0.enabledtemplate,A0.templatedtemplate,TO_CHAR(A0.createStampA2,'dd mm yyyy hh24:mi:ss'),A0.markForDeleteA2,TO_CHAR(A0.modifyStampA2,'dd mm yyyy hh24:mi:ss'),A0.idA2A2,A0.updateCountA2,TO_CHAR(A0.updateStampA2,'dd mm yyyy hh24:mi:ss'),A0.title,A0.branchIdA2typeDefinitionRefe,A0.idA2typeDefinitionReference,A0.versionIdA2versionInfo,A0.versionLevelA2versionInfo,A0.versionSortIdA2versionInfo,A0B.classnamekeycontainerReferen,A0B.idA3containerReference,A0B.docType,A0B.name,A0B.WTDocumentNumber,A0B.classnamekeyorganizationRefe,A0B.idA3organizationReference,A0B.series,TO_CHAR(A0B.createStampA2,'dd mm yyyy hh24:mi:ss'),A0B.markForDeleteA2,TO_CHAR(A0B.modifyStampA2,'dd mm yyyy hh24:mi:ss'),A0B.classnameA2A2,A0B.idA2A2,A0B.updateCountA2,TO_CHAR(A0B.updateStampA2,'dd mm yyyy hh24:mi:ss'),'wt.representation.OutOfDateRepresentationLink',A1.classnamekeyroleAObjectRef,A1.idA3A5,A1.classnamekeyroleBObjectRef,A1.idA3B5,TO_CHAR(A1.createStampA2,'dd mm yyyy hh24:mi:ss'),A1.markForDeleteA2,TO_CHAR(A1.modifyStampA2,'dd mm yyyy hh24:mi:ss'),A1.idA2A2,A1.updateCountA2,TO_CHAR(A1.updateStampA2,'dd mm yyyy hh24:mi:ss') FROM WTDocument A0,WTDocumentMaster A0B,OutOfDateRepresentationLink A1 WHERE (A0.idA3masterReference=A0B.idA2A2) AND ((A0.markForDeleteA2 = 0) AND (A1.markForDeleteA2 = 0)) AND ((A1.idA3A5 = A0.idA2A2) AND (A1.idA3B5 IN (SELECT /*+ CARDINALITY(wtot 3300) */ * FROM TABLE(cast(? as WCADMIN.TABLE_OF_NUMBER)) wtot WHERE (ROWNUM > 0) AND (column_value IS NOT NULL))))
/*+ CARDINALITY(wtot 3300)/ CARDINALITY causes SQL queries to be very slow, Windchill official bug
Do you have some background behind this? Is there an SPR number or CS article on this? This article, https://www.ptc.com/en/support/article/CS130564?source=search, is not the exact query but points to having to create an index.
