CN Affected Objects Table
GregOlson
I want to shrink the size (rows) or remove the column containing the comments for affected objects. It looks like each object in the affected objects table takes up 3-4 rows. We currnetly only add comments to the resulting object table. What file should I look to modify?
KD
(To:GregOlson)
Hi Greag,
Go to pick a view --> Customize
from the next window click on edit view .
Afterr that go to set column display and from there you can select what column you want to dispaly at the table.
Kaushik
KD
(To:GregOlson)
Hi Greag,
Kaushik
GregOlson
(To:KD)
Thanks for the info. For some reason on my system I could not exclude comments by modifying views. I had to deselect it by hovering over the right side of a column, clicking the down arrow that appeared, selecting column, and then I could deselect comments. I wish the column down arrows would stay shown all the time...out of sight out of mind.
Greg
KD
(To:GregOlson)
Hi Greg,
You can deselect it but I guess next time when will you again create the change task the comment will come again so every time you have to Deselect whenever you will create a new task.
That change is not permanent.
Kaushik
GregOlson
(To:KD)
Once again our system must be different than yours, our changes will stay until browser cache is cleared.
