Version: Windchill 12.1
Use Case: I am trying to create a report showing all Change Notices together with their associated Change Requests. The CR's are associated in 2 different ways: - Associated Process Objects - Associated Reference Objects I want to create an overview were both associated types CR's are shown. If possible it would be nice to show the association type in the overview as well
Description:
I can't get the report to include both link types in one overview.
If I create two reports: 1 for the Change Process Link and 1 for the Change Reference Link and merge the two in excel I get wat I want but I think this should be possible in 1 report....
I also found out about the option "Outer Joint Against" you need to set this correct to also show CN's with no CR's associated to it. Is there a way to show both:
- the CN's with no associated CR's
- the CR's with no associate CN's
Any good tips to speed up my learning experience are welcome. Courses / books / websites....
Best regards,
Dennis Varkevisser
This is a good start point to learn about reporting
ptc.com/en/support/wnc-reporting-landing
Here a generic HUB article divided in section
[Knowledge Hub] Windchill PLM -Business Reporting
Here something similar to your needs
Hi @DV_10922158,
Anurag
