CREO BOM with Nested repeat region
SwapnilKadu
Hello All,
I am facing an issue with Creo BOM using nested repeat region.
In the BOM I am showing the main assembly & the next level sub-assemblies & parts. To show weight in BOm I am using &WEIGHT parameter.
When I create the BOM every part shows correct weight, I save the drawing & close it. But when I reopen the drawing the weight of 1 part is changed automatically & I have to regenerate the drawing to get the correct weight displayed in the BOM.
Can anyone tell me why this is happening? What is the solution for this?
This is just a guess, but I'd investigate the references on the part where the weight is changing. I've found that this type of "fine and then it's not" behaviour often has a root cause in it's references.
