Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Has anyone had success syncing this data? Is this even possible to take the calculated cable lengths and drive a BOM unit of measure and quantity?
Antonio Villanueva - Sr. Software Engineer - ISR Systems UTC AEROSPACE SYSTEMS 100 Wooster Heights Road, Danbury, CT 06804 Tel: +1 203 797 5682 antonio.villanueva@utas.utc.com<">mailto:antonio.villanueva@utas.utc.com>www.utcaerospacesystems.com CONFIDENTIALITY WARNING: This message may contain proprietary and/or privileged information of UTC Aerospace Systems and its affiliated companies. If you are not the intended recipient please 1) do not disclose, copy, distribute or use this message or its contents, 2) advise the sender by return e-mail, and 3) delete all copies (including all attachments) from your computer. Your cooperation is greatly appreciated.
