Intralink 9.1 M050
Hi Gang,
May be a basic question, but the CM group is pretty much on autopilot here and I never have to deal with this aspect of the process/solution.
My CM resource accidently "Approved" an ECR and she wants me to set the state back to "Under Review" so she can "Reject" it this time.
I am full blown orgadmin
Any insight?
David T. Francis
I don't see why not since it is just a request and not the notice. As long as you catch it before you applied it to the change notice. There are always some administration resets because items accidentally gets approved.
If you are an ORG admin, you can always do a Set State on the Object to a specific state.
Are you able to Set State from Implementation (or Resolved) to Under Review and push out a task to additional CRB members? Use case is 5 CRB members already approved the ECR but after the ECR was approved, the team realized a 6th Approver was required. How can we obtain approval 1. without terminating the existing approvals, and 2. without restarting the workflow and requiring the full team to re-approve?
