Can I install Windchill 11.00 on SQL Server Express?
SOLVED
Highlighted
Amethyst
Can I install Windchill 11.0 on SQL Server 2012 Express?
I already have an instance of SQL Server 2012 Express and would like to use this for my new Windchill installation.
Any assistance would be helpful,
Tags (1)
1 ACCEPTED SOLUTION
Highlighted
Re: Can I install Windchill 11.00 on SQL Server Express?
Yes, it can be done and will run fine as long as it's a relatively small installation.  Keep in mind that it won't be supported by PTC.
Highlighted
Highlighted
I also have noticed in Windchill 11, data definition files for using PostgreSQL database.  I have not explored it any further yet.
Highlighted
Please go through the Software Matrices through the below link to check the compatibility
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS235374&art_lang=en&posno=2&q=software%20m...
