Can anyone give me the correct CSV syntax to be able to use the CSV2XML utility to load parts that have std IBA's?. An example would be very helpful.
PaulJones
Here you go. This is what I have been using.
Thanks Wayne.
Your example is loading Global IBA values. I have a very similar load file for that use case.
Unfortunately I am trying to load STD IBA's.
Paul
OK sorry
