Can't Move CAD Document to another Product
Regular Member
I'm trying to move an assembly (CAD Documents) from one Product into another Product. I get an error "You cannot move these objects because you do not have the necessary permission to change context for one or more of its versions."
Both Products use the same lifecycle. The Policy Administrator says that I have the following permissions for the state in both Products for EPM Documents:
Read, Download, Modify, Modify Content, Modify Identity, Create By Move, Create, Change Domain, Delete
Is there a missing permission or some other reason why I can't move this assembly?
Pro/Intralink 9.1 M020
Andrew Kelly, P.E. | Senior Engineer | Crane Aerospace & Electronics | +1 440 326 5555 | F: +1 440 284 1090
