I am using Windchill PartsLink Release 11.2 and Datecode with CPS 11.2.1.10
my naming is not visible fully and my name field contains the length only 60 character and my autonaming length is around 94 character so that's why it is not showing full naming and we can't change length of the name field. so my question is we can apply the autonaming rule to the different field like description or any other attribute instead of name field?
For more clarification please connect with - suraj.devarde@piterion.com
Hi @SV_10589706,
Yes, we can have autonaming applied to other attributes as well through OIR.
But its better to customize the name attribute character length by following the below article
https://www.ptc.com/en/support/article/CS155068?source=search
hello, i want to apply that in other attribute which is german name so how can i change in OIR do you have any sample example
