Can we get the iteration history of an object linked to a workflow task
Anand
Dear Experts,
I Would like to get the iteration history of an object which is linked to a particular workflow task for instance
If I have the workflow tasks like Review, Rework, Submit etc I would like to know which iteration of the object is linked to the task Review, ( Perhaps 1.2 ) and also for other tasks ( Rework, Iteration of the document 1.3 ) etc..
I would like to get this information displayed in the workflow process status table
Is there any way to display this information using Windchill UI ?
I am working on Windchill 10.1 M110
Thanks for your help and let me know if you have any questions !!!
Regards
Athmanand
You can add any strings and variables in the instruction field of the task. So you can calculate string variable in the expression robot before your task. Include this variable like {varname} in the instruction field.
Note: variable must be global and be defined as a local variable in the task.
Hello Antoan,
Thaks for your reply,
Athmanand
Hello. I wrote you about instruction field in the Details tab.
