Can we prevent Promotion Request creators from selecting themselves as an Approver?
JeffNorton
11-Garnet
We want to prevent a user from approving their own documents. However, this users may be an approver of the same document type created by another user.
It is possible to use the available API's in an expression robot within the workflow, but I would like to see this as an available business rule that while still requiring an expression robot would be easier for most to implement
slapha
(To:JeffNorton)
Not the easiest way but it's possible.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS180902
Someone else posted this as well as a method to check after the fact and remove them.
Solved: How to Check if Creater has added himself has a Pr... - PTC Community
