Can we register a listener for any event of a specific object?
vkhole-2
2-Guest
eg. listener service should be called for any event occurring on wtpart or a different listener should be called for any event occurring on wtdocument
mgupta-2
6-Contributor
(To:vkhole-2)
Yes you can..
You just need to implement the performStartupProcess() and in that method you can control which object type and event should be invoked.
eg.
protected void performStartupProcess() throws ManagerException
  try
getManagerService().addEventListener(new ServiceEventListenerAdapter( this.getConceptualClassname() )
                public void notifyVetoableEvent( Object event ) throws WTException,PropertyVetoException,WTPropertyVetoException
                WorkInProgressServiceEvent persistenceEvent = (WorkInProgressServiceEvent)event;
  //System.out.println("\n\n .performStartupProcess() starting for POST_CHECKIN..");
                if( persistenceEvent.getEventTarget() instanceof WTPart)
  Object object = persistenceEvent.getEventTarget();
  //handleUploadEvent(object);
  if(enablePostCheckIn.equalsIgnoreCase("true"))
  handlePostCheckInEvent((WTPart)object);
},WorkInProgressServiceEvent.generateEventKey(WorkInProgressServiceEvent.POST_CHECKIN));
Thanks a lot Mahesh, il implement it and let you know the updates
