Can we set few table rows as pre-selected and few rows as Non-Selectable?
mbhadiyadra
Hi , As shown in image, all rows are pre-selected through data utility
In Tree-Builder :
ColumnConfig localColumnConfig2 = localComponentConfigFactory.newColumnConfig("abc", false);
localTreeConfig.setPreSelectableColumn(localColumnConfig2);
In xconf :
<Option serviceClass="PreSelectRowDataUtility"selector="abc"cardinality="duplicate"requestor="java.lang.Object"/>
In Data Utility :
public class PreSelectRowDataUtility extends AbstractBooleanValueDataUtility
  public boolean getBooleanAttributeValue(String paramString, Object paramObject, ModelContext paramModelContext) throws WTException
   return true;
Now we want first row as Non Selectable. There should be no checkbox in first row.
for that there is ptc method
localTreeConfig.setNonSelectableColumn(localColumnConfig2);
and DataUtility AbstractNonSelectableRowDataUtility
But there is already one data utility registered in xconf regarding this column"abc" . how we can do implement both functionality togather ?
Requesting for Help. Thanks
Hi Manthan,
Did you check the example provided in the carambola examples, try following link on your server, replace the host appropriately.
https:/<hostname>/app/#ptc1/comp/carambola.mvc.tree.async
Basically in the example, if the number contains "3" or "1" the rows are pre-selected and if the number contains "7" or "4" (irrespective of first condition)the rows are non-selectable.
This is how it is implemented in the code:
  ColumnConfig col2 = factory.newColumnConfig("treeNonSelectableColumn", false);
           col2.setDataStoreOnly(true);
           col2.setNeed(NUMBER);
           tree.addComponent(col2);
           tree.setNonSelectableColumn(col2);
           //Pre Selected column
           ColumnConfig col3 = factory.newColumnConfig("treePreSelectableColumn", false);
           col3.setDataStoreOnly(true);
           col3.setNeed(NUMBER);
           tree.addComponent(col3);
           tree.setPreSelectableColumn(col3);
           tree.addComponent(factory.newColumnConfig(NUMBER, true));
Same columns listed twice with different dataUtilities.
Bhushan
