Can you guide me on how to resolve below Task failed
KS_9212978
6-Contributor
LocateClassReferences:
Scan the database for references (i.e. foreign keys) to specified classes or non-existent classes. To locate references to specific classes, specify the list or pattern in the classes field. To locate references to classes that do not exist, do not specify a list of classes. To see all the SQL statements that are executed by this task, select the verbose logging option. If the verbose logging option is not used, the sql for found references will still be logged.
I got below error when I run WINDU , can you guide me on how to resolve below Task failed. Thanks in advance for your support.
at java.lang.Thread.run(Thread.java:745)
Task failed.
com.ptc.windchill.upgrade.updates.UpdateExecutionException: Error executing IncrementalUpdate Locate class references (#LocateClassReferences)
Nested exception is: (com.ptc.windchill.upgrade.updates.directives.directivesResource/39) com.ptc.windchill.upgrade.updates.DirectiveExecutionException: Method server code wt.fc.LocateClassReferencesDT.runDiagnostics failed. See nested exception for details
Nested exception is: wt.util.WTException: java.lang.reflect.InvocationTargetException
@KS_9212978
Thank you for using PTC Community!
Could you please add some screen-shots which may help other community users to understand the issue better?
Community Moderation Team.
I just did a search on PTC knowledge base and found this article
https://www.ptc.com/en/support/article/CS389899
This could be the reason of your error
Custom templates are present in the Source environment however related LoadXML files does not exist in Target environment
Marco
And this could be another reason for your WINDU failure
https://www.ptc.com/en/support/article/CS319706
Do not config the Windchill integrate with Active Directory Server correctly
There is no users from Active Directory Server, but the AD server adapter was set in properties wt.federation.org.directoryServices
Marco
