I have 2 monitors can you have Windchill gui on one monitor & Creo on the other?
Yes, there is a config.pro option to separate the imbedded Windchill browser.
It is always possible with an external browser to Windchill while running Creo.
Thanks Ben but could you tell which category its under as I dont see it.
WEB_BROWSER_IN_SEPARATE_WINDOW
Thanks Ben you made my Friday
You can also just open a regular web browser and use that as well. This will give a view of what is on the Windchill server, which may be different that what is seen using the integrated browser. It is also usable when you are not using Creo.
