I have one attribute and enabled a constraint string , length of string is 1200, however on information it is not showing the complete value, it truncated the string after 700 characters.
To see the complete value I have to edit it.
Hi ,
can you edit the group attribute properties in the given layout
Yeah, I can see this , but cannot edit.
Is there any way to change these values ?
Thank you so much for the help.
