Change Distribution
wfalco
Change Distribution
Greetings,
How do I change distribution in Windchill? See attached sample screen shot. Would be great if I can select all and change to "D". Do I know what version of Windchill I have? No. It's hidden somewhere I suppose.
UPDATE: (thanks to Ben)
 11.0 M030-CPS13
Hopefully this is it.
Wayne
BenLoosli
(To:wfalco)
The version is easy to find.
Quick Links in the upper right, then Help, the  About WIndchill.
You can also get the version information from a Windchill Command Prompt by typing 'Windchill Version'
Thanks Ben...yeesh...I am blind today.
The command prompt thing does not work. Propably set up for you?
Wayne
BenLoosli
(To:wfalco)
It has to be the Windchill Shell command prompt window for Windchill commands.
The normal Windows command prompt window does not work.
