Greetings,
How do I change distribution in Windchill? See attached sample screen shot. Would be great if I can select all and change to "D". Do I know what version of Windchill I have? No. It's hidden somewhere I suppose.
UPDATE: (thanks to Ben)
Wayne
The version is easy to find.
Quick Links in the upper right, then Help, the About WIndchill.
You can also get the version information from a Windchill Command Prompt by typing 'Windchill Version'
Thanks Ben...yeesh...I am blind today.
The command prompt thing does not work. Propably set up for you?
Wayne
It has to be the Windchill Shell command prompt window for Windchill commands.
The normal Windows command prompt window does not work.
