I have some files (100K) uploaded to Windchill (File > New > Document) with extions *.abc and I would like to change it to *.pqr. What should be procedure to do it?
Any help on this will be appreciated.
Milan
Bump. I need help on this issue as well...
It's all in the database. You will need to join several table to get what you want, but updating should be pretty straight forward.
Take a look here to get you started: Re: Report on WTDocument File
Let me know if you need more info.
