When we started with Change Management in PDMLink I thought we were told that there is a character number limit for ECN Number. Something like maybe 11 characters. I remember this because I remember talking with our consultant about if we add the letters "ECN" in the number as the prefix. The response was the more characters you use as a prefix means the less number of total characters you can use for the automated number part.
As an example we have the text "ECN" in the number and if the total number of allowed characters 11 then we have 8 digits to use for that actual real number part of it.
ECN12345678
But if we used 4 prefix characters, something like PECN (for Prototype ECN) then we have only 7 characters left to use.
@STEVEG ,
OOTB the limit for the number of characters for a Change Notice number is 32.
If you check in the dB where the number is stored it's clear that 32 is the limit.
In the image below the you can see four Change Notices.
The first two where created using OOTB OIR
The third was created with OIR sequence generator set to 32
The fourth was created with OIR sequence generator set to 29 as it included a three character prefix, ECN.
If you experiment with the OIR and set the prefix and/or the sequence generator such that the number's length would be greater than 32 an error window will appear when you try to create the Change Notice.
Does this answer you concern?
David
Hi Steve,
the number of characters for an ECN is 12 (see attached image).
However, I wonder why you want to use part of these characters to describe the object (ECN) and the status, which are two information already available in the system.
There are a few reasons. One is so it is easy to identify in Tasks and emails what it is. Is it an ECR, an ECN or a Task. That way our users get a better sense of what is needed to be reviewed first.
@STEVEG ,
David
Is 32 the limit for a Task as well?
