Hi there, did somebody has tested entirely the change management in Windchill 12.0.2.x? For me exist incredibly many errors for Change Notices. E.g.
Are there any other known issues in the area of change management? Have any community members already done extensive testing in this area? Thank you very much for any response.
All my open tickets are confirmed to be fixed in 12.0.2.3 released by the end of December 2021.
Thanks PTC 😉 especially @JeffZemsky
Oh great. We are on 12.0.1.2 with expectations of going to 12.0.2.x soon. The reason for that is because the New Folder icon is missing for standard users but is supposed to be fixed in the latest build.
I am trying to understand the extent of this problem. Does the multiple object state change fail in all the following circumstances or just some?
Setting the release target for multiple objects is failing in general.
A new article has been released for the case: https://www.ptc.com/en/support/article/CS343101
@BjoernRueegg So PTC cannot reproduce the issue you are having and therefore won't fix it?
@LawrenceS PTC is reacting. I had contact with Jeff and he will look in it. It looks like he has already checked the cases. Because all of them will be fixed now.
Today I just searched for the SPRs and it looks like they are going to fix both in 12.0.2.3 👍
If anyone else has tested 12.0.2, can you reply as to whether or not you can set state of multiple objects?
You're definitely not the only one. I was just taking to my sales rep. at EAC yesterday and he has a large customer in the area who is having this exact same issue. Apparently PTC is being very unresponsive about the whole thing. I can give you his contact info if you want to send me a PM.
Unfortunately the bug with the target state is back in 12.0.2.5. Target state selection which will not be saved during change task creation.
Does anybody has 12.0.2.5 or 6 to verify it?
