Is it possible to Create 1 ECN that refers to or encapsulates many ECRs raised on the same item.
I have several ECRs raised on the same document.
Currently 1 submission / approval of ECR creates 1 "Create Change Notice" task in our Windchill 11.2 system.
So I get a new document revision for each change request/ change Notice.
I only want to have one revised version of the document for the multiple change requests.
How do I do this???
You can add as many CR's to a CN as you want. I think it's available out of the box. You just add another CR to the CN on the fourth page of the CN. There are preferences to allow many CR's to many CN's.
Here are the preferences relating to Change Management that SteveG was mentioning. You can tailor them, to allow for many to many, but I'm not sure that is what Paul is looking for...sounds like he's good with the out of the box preferences instead. But anyway, these prefs will allow you some tailoring of this.
There should also be a preference to turn off auto-ECN creation.
