Change Request Summary report Description
rleir
When we run the Change Request Summary report  (Actions -> View Summary Report), the Description and Proposed Solution fields are blank.  The other fields get reported correctly.
We also get an Error which might not be related:
[ContainerBackgroundProcessor[StandardEngine[Catalina]]] com.ptc.netmarkets.util.misc.DBOperationHttpSessionListener - No active method context
wt.method.server - Dead method context [id= ... ... ]  threadName=Thread-nnn] was never unregistered
This is a Jasper report.
thanks -- Rick
What version of Windchill? This could be because description and proposed solution are RTF as of 11.1. See support case:
https://www.ptc.com/en/support/article/cs298196?language=en&posno=2&q=rich%20text&source=search
7 REPLIES 7
rleir
(To:rleir)
Hi team:
This failure is consistent on every run of the  Change Request Summary report.
Same on a very lightly loaded WC server.
(I have been told 'This would be a priority issue')
We also get an Error log:
Message: Dead method context [id=nnn, threadName=Thread-nn] was never unregistered
Context Label: /Windchill/netmarkets/jsp/report/jasper/jasperAsyncHeartBeat.jsp
Is that related?
Do we have to configure HeartBeat as described in the following page?
https://community.jaspersoft.com/documentation/jasperreports-server-administration-guide/v550/configuring-heartbeat
I have not mentioned this to our security people yet.
thanks -- Rick
rleir
(To:rleir)
Hot on the trail through:
$ view loadFiles/reports/LoadJasperChangeManagementSummaryReports.xml
$ view codebase/netmarkets/jsp/changeReports/ChangeRequestSummaryReport.jsp
$ view codebase/netmarkets/jsp/changeReports/ChangeItemSummaryReport.jspf
$ view codebase/netmarkets/javascript/change2/changeReports.js
Still trying to get the Description and Proposed fields populated.   Please help
cheers -- Rick
As you say, this is probably a RTF issue. But after much work trying to reconfigure everything to work with RTF, we come up with a roadblock in ODATA which does not seem to support the RTF fields.
Who is able to get the RTF fields via ODATA? How did you do it?
thanks -- Rick
rleir
(To:rleir)
Also, is there a way to configure the Change Request Summary report to use the old non-RTF fields? This is the OOTB Jasper report at
domain.com/Windchill/netmarkets/jsp/report/jasper/reportViewAsync.jsp?
contextOid=VR%3Awt.change2.WTChangeRequest2%3A170009271&
oid=com.ptc.windchill.enterprise.report.Report%3A374985952&
When viewing a Change Request, in the Action menu select 'View Summary Report'.
thanks -- Rick
rleir
(To:rleir)
Ping
rleir
(To:rleir)
The .jasper file can be found at:
Windchill]$ ll codebase/JasperReports/Change\ Management/Change\ Request\ Summary\ Report.jasper
-rwxr-xr-x. 1 winadmin winadmin 160069 Jul 29 23:55 'codebase/JasperReports/Change Management/Change Request Summary Report.jasper'
You can take a copy of this and open it in the Community Version of Jasper Studio. Click the 'Source' tab and you see the .jrxml code: it seems to have been de-compiled from the .jasper. The rich text fields can be located. Small changes were made to the data-source spec code so we would get the non-richtext data. But we still get a blank output in these fields. The relevant .jrxml lines, 782 and 783:
								<textElement markup="html"/>
								<textFieldExpression><![CDATA[$F{Description}]]></textFieldExpression>
Maybe I need to locate the data adaptor class and modify that too?
