Change Validator extension
Iblackie
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.1
Using extension Change Validator the "Validate Change" step 3 only appears during OOTB change notices not on Change notices with templates or change notices using sub-types. Creating a new change notice template does not show this "Validate Change" step either.
5 REPLIES 5
I would open a ticket with Wincom
HelesicPetr
(To:Iblackie)
Hi @Iblackie
Does the extension some admin settings, where you could be able to set the subtype of promotion to work on?
I would expect some configuration options to allow the checking on specific promotion subtypes
PetrH
Not currently.
Hello Iblackie,
You encountered unexpected behavior while using Windchill, thanks for reaching out.
This is Charles from PTC Technical Support in Europe: did you get a chance to open a new case for this question?
KR,
Charles.
Iblackie
(To:cgautier)
I have a ticket open with PTC Tech Support, It may be related to my menu display setup for subtype. reference ticket Case Details: 16950071 (ptc.com)
I'll post my findings once resolved
