Hi everyone,
I have a little problem and I really hope someone can help me with that.
I created an EPMDocument by using an expression robot. Now I would like to automatically check-in this EPMDocument into the commonspace via a Java code, so that not only the person who created the document can see it in his workspace but also everyone else. I tried to use a method robot (for check in) for this, but that caused an error.
Can anyone please help me or point me in the right direction?
I'd really appreciate it.
Willi
I would recommend not to enter so much code into an expression robot. Call a java class from expression robot.
I wrote a small code that creates EPMDocument (works on 9.1 M40). Use it as reference for your use.
For check-in, you can use following API in expression robot itself. For you, object is EPMDoc and note is checkin comments.
wt.vc.wip.WorkInProgressHelper.service.checkin(Workable object, String note)
Side Note: If its a brand new EPMDocument, you might want to persist it. For you, obj is EPMDoc.
wt.fc.PersistenceHelper.manager.save(Persistable obj);
Thanks for the quick response.
Your answer does work, but unfortunately not for brand new EPMDocuments. After implementing the code and running it I get the following error:
wt.workflow.engine.FailedExpressionException: wt.util.WTException: (wt.vc.wip.wipResource/36) wt.vc.wip.WorkInProgressException:
WARNING: The element notebook - Layout, A.1 must be checked out in order to be checked in.
What should I do?
Willi
Did you happen to try this API?
Yes, I tried that API, but I still get the same warning. Element must be checked out in order to be checked in.
Maybe it's better to show you the hole code.
wt.epm.EPMContextHelper.setApplication(wt.epm.EPMApplicationType.toEPMApplicationType("EPM"));
wt.epm.EPMAuthoringAppType at = wt.epm.EPMAuthoringAppType.toEPMAuthoringAppType("PROE");
wt.epm.EPMDocumentType dt = wt.epm.EPMDocumentType.toEPMDocumentType("LAYOUT");
wt.query.QuerySpec qs = new wt.query.QuerySpec(wt.epm.workspaces.EPMWorkspace.class);
wt.epm.workspaces.EPMWorkspace workspace = null;
qs.appendWhere(new wt.query.SearchCondition(wt.epm.workspaces.EPMWorkspace.class,wt.epm.workspaces.EPMWorkspace.NAME,wt.query.SearchCondition.EQUAL,"the SPECIFIC WORKSPACE"),new int[] { 0 });
wt.fc.QueryResult qr = wt.fc.PersistenceHelper.manager.find((wt.pds.StatementSpec)qs);
System.out.println(qr.size());
while(qr.hasMoreElements())
workspace = (wt.epm.workspaces.EPMWorkspace)qr.nextElement();
epm=wt.epm.EPMDocument.newEPMDocument(number, name, app_type, doc_type, cad_name);
wt.inf.container.WTContainerRef container_ref = wt.inf.container.WTContainerRef.newWTContainerRef(workspace.getContainer());
wt.inf.container.WTContainerHelper.setContainer(epm, container_ref);
wt.folder.FolderHelper.assignLocation((wt.folder.FolderEntry) epm, workspace.getFolder());
wt.vc.wip.WorkInProgressHelper.service.checkin(epm, noteEpm)
wt.fc.PersistenceHelper.manager.save(epm);
Hopefully, you can tell me what is missing or wrong.
Thanks again,
Willi
wow,
one more,
How to newEPMDocument set CreateDate ??
CreateDate in not today. i want another day.
Yogesh, How to upload a content file to the EPMDocument?
Raghu
Hi Yogesh,
i am facing one error while Uploading a modified content to a epmdcoument which is created by using API.
here is brief,
1. i have created an EPMDocumet by using API ( Simple .prt).
2. this EPMDocument is opening in Creo as well.
3. all actions like, check out, check in, undo check out , add to workspace from Browser are working fine.
4. checked out operation from creo also works fine.
5. now i have made some modifications in this epmdocumnet in creo.
7. now try to check in these modification in Windchill from creo - check in options.
8. here, before check in, it will upload this modification to server, but this upload operation was failing and ultimately i am not able to check in the epmdocument from creo.
here is my error,
Please help us to fix this issue.
Thanks, Vivek
Hi guyz,
I created workflow, which need to execute when EPMDocument checked in from PROE. I set Workflow in INWORK state of EPMDocument lifecycle.
I added synchronize robot on CHECKIN event of EPMDocument in workflow immediately after START , I added below code in synchronize robot that if EPMDocument path doesn't contain EPMDocument creator name then only proceed workflow .
However the workflow executes when I click SAVE & UPLOAD the Drawing in PROE, rather It should be executed when I click CHECK IN the Drawing.
So When I click CHECKIN , workflow doesn't execute Synchronize robot because it already executed ...
Does anybody have idea , How I can solve this issue?
primaryBusinessObject is EPMDocument
if ( primaryBusinessObject != null ) {
String stringCreator = ( (wt.epm.EPMDocument) primaryBusinessObject ).getCreatorName() ;
String stringForlderPath = ( (wt.epm.EPMDocument) primaryBusinessObject ).getFolderPath() ;
if( ! stringForlderPath.contains( stringCreator ) ) {
result = "ok";
