Hi All,
Trying to achieve Check in of WTPart should fail from workspace is a attribute is missing.
Made the attribute required in Type & attribute however still it gets checked-in from workspace.
Any reference what needs to be done.
Thanks in advance
Do you have any other constraints enabled for the attribute, besides Required?
Perhaps the user is checking in with putting a space or some other empty character?
I've applied cascading on WTPart so the, by default the attribute is selected as undefined.
Guess that could be the reason it checks in.
This is an OOTB "feature". The workspace checkin will not check the required attributes. This is good for engineers to work fast but bad for the quality 😉
I would suggest to implement the attribute business rule to check the values before releasing the WTPart.
This is a good idea.
