The default clipboard size is 250, the models my company generates are far larger (average 5k, however, 15k files is not out of the realm of possibilities). Inside a change notice anything after 1000 causes massive delays if it ever completes. How else do I add the items to the Affected Items box or include them as part of the change?
Hi @agarr
Have you ever used the collector inside of change table? It can collect many linked objects
or you can increase clipboard limit more info in Windchill-Clipboard-limit
PetrH
@HelesicPetr I tried moving the clipboard limit to 2500 and the system will hang and never complete for the finish step of the Change notice creation. For ~2400 items in a change notice it took over 2 minutes just to revise. I can't get it to finish over 2500 items, doesn't matter how I start or using the collector. Moving to the Affected items box is delayed but completing the change notice is worse.
