Code to copy files from client system to serversystem
ddemay
7-Bedrock
While this is possible you need to consider the file names are changed in the vault. Assuming your not persisting them as blobs in the DB. It's not just a simple set of code to handle transfer IO between server and client. Can it be done yes? I'm not sure if its worth doing it this way.
Sent from my Verizon Wireless BlackBerry
avillanueva
23-Emerald I
(To:ddemay)
Easier to use a CSV load file and post the files locally to the server.
