Hi all,
Will there be help in WC 12 for people upgrading from WC 11 with many Cognos reports, to help them migrate the reports to Jasper?
thanks -- Rick
Some background information for the thread
I also have this question!
And more generally, how long can we continue to use the old Cognos reports? Someone said that they would continue to run until 12.01 but you should consider that hearsay. And that the out-of-the-box Cognos reports would be converted to Jasper by PTC? But if, further to that, you wrote more Cognos reports you might need to acquire a Cognos license from IBM? There are several questions above, please help!
cheers -- Rick
Hello Rick,
Not sure of you got the answer to your request, just found it. to answer your questions:
I hope this helps
Nisrine
I would like to see a help topics describe the migration steps from cognos to Jasper.
In our cases there are many customers used their custom cognos reports and it takes long time to learn how to migrate all reports.
Some customers have cognos reports which were time consuming to create .
What about history of saved reports ?
In my opinion this topic is not so easy like some could think.
Best regards
PetrH
Hi Nisrine and Petr
There is also the small issue of Oracle versions. Careful, if you upgrade Oracle to the latest version compatible with WindChill then your Cognos reports will all fail. There is a previous revision of Oracle which is a 'sweet spot': upgraded enough but not to the latest. Sorry to be vague, but it's n.m.3 .. you will have to look it up.
As for Jasper, there is some documentation in the PTC help pages. For Jaspersoft Studio, PTC directs you to the TIBCO community documentation. The Jasper server from the open source project seems have been integrated by PTC into the Windchill server but we don't have much documentation on that.
cheers -- Rick
Do we know which version of Jasper was integrated into Windchill and whether or not Jasper REST API (described here) is exposed?
@JoePaul argh - I see it is missing from the 3rd party list. We will get that fixed - I'll get the info posted here. We added support to use Odata from WC with Jasper with WC 12.0.2
@JoePaul it looks like you are referencing JasperReports Server. The Capability in Windchill is built on JasperReports Library
You can find information on working with WRS API here:
Hi Jeff
Thanks for that info.
In point 4, the FAQ that you link to gives me :
Rick
@rleir The article should be available today if it is not already. Sorry for the confusion.
Jeff
In point 3, you say
"Data sources such as [...] Info*Engine can be reused in creating reports with JasperReports Library"
Is there a simple example of how to use Info*Engine? I don't find the help pages on this useful:
thanks
Rick
@rleir - it might be the same data sources as one currently uses in a Cognos. If you are not currently using Info*engine sources in your custom reports I am not sure that I would add ones now - I'd look at Query Builder and/or WRS as options first.
Hi Jeff
This other article is also not accessible, that makes two articles.
This article 354393 is not customer visible.thanks -- Rick
Sorry for the delay - it was made available today
I can check on the other as I am not familiar with it.
