You will find that ALL third-party WGMs lag behind Creo integration into Windchill by a few months (or more).
If the Revit files are just AutoCAD formatted files, the WGM should not have any issues. But I don't think that is the case. 😞
If it was, you would not need WGMs for AutoCAD basic, Electrical and Mechanical, as they are all the same formatted files. I do understand that xrefs and other imbedded 'symbols' into these files may be handled differently, but I am no AutoCAD expert in understanding the file format structures.
I did see 2020 but only supported with 11.2.1.
Here is the link to the 11.2 list of compatible CAD products.
https://www.ptc.com/support/-/media/9CD3FD15F28F4C24922DAF4CDD820266.pdf?sc_lang=en
AutoCAD Revit is not on the list.
Thanks Ben,
Scrolling down I saw the versions for AutoCAD. Only up to 2019 so far, and no mention of Revit and maintaining the links heading into Windchill. I'll contact support.
Thanks!
Hi Krissel,
You can try the Revit Workgroup Manager for Windchill developed by SrinSoft in partnership with PTC, to synchronize all your Revit files to Windchill along with the reference files, drawing sheets, BOM, etc. You can even publish the Revit file as a Creo viewable. You will find more info here - https://www.srinsofttech.com/revit-windchill-plm-integration.html
Hope this helps!!
Hey,
You can use the BIMDeX product, which can specifically deal with your problem
