Configurable windchill reports
sdicarlo
6-Contributor
Version: Windchill 12.0
Use Case: customize the ootb engineering change summary report to add several attributes used for non- Windchill users/customers/vendors.
Description:
Create the Engineering Change Notice Summary report with the following attributes:
Life Cycle State
Change Class
Requestor
Responsible Engineer
Business Unit
Customer approval required
Reason description
Proposed change
New revisions
Resulting objects with dispositions
list of votes with final vote date, role,name of user
5 REPLIES 5
AndrewK
Community Manager
(To:sdicarlo)
Hi sdicarlo
Thank you for your question. I’d like to recommend bringing more details and context to your initial inquiry. It also helps to have screenshot(s) to better understand what you are trying to do in your process. This will increase your chances to receive meaningful help from other Community members.
There are dozens of report about query builder on the Knowledge base.
This is about relationship of change object
How to understand Change Management objects and their relations
Marco
AndrewK
Community Manager
(To:Marco_Tosin)
Hi sdicarlo,
I wanted to follow up with you on your post to see if Marco_Tosin's reply helped answer your question. If so, please mark the reply as the Accepted Solution for the benefit of other members who may have the same question.
Of course, if you have more to share on your issue, please let the Community know.
Thanks!
rleir
(To:sdicarlo)
Sorry for the delay in answering.
Is this an OOTB report? Our Windchill does not have a report like that. Perhaps we simply have a different configuration (this is very likely).
Your report is not a Query Builder report.
The 'Business Reporting' subsystem has changed from Cognos to Jasper.
The OOTB reports in WC 12 are Jasper reports.  Any remaining Cognos reports you might still have would be custom reports, and please beware that Cognos support is being phased out.
You need to:
  • Find the admin who knows how to modify Jasper reports
  • or (less likely)  Cognos reports
HelesicPetr
(To:rleir)
Hi @sdicarlo
the Engineering Change Notice report is definitely not OOTB one. especialy with a company logo.
So you should contact a person who is responsible for that report.
System administrator can help you to say who is it.
PetrH
