Hi Community,
I am using PartsLink on Windchill 12.0.2.0.
I want to reorganize some sheets of the PartsLink classification tree. when i copy a leaf and want to place it in the new branch, nothing happens. Not when I select copy with attributes nor when I select copy without attributes.
The branch to be copied is not assigned to any part.
If I create a new sheet and copy it to a test branch, it works.
Does anyone know which attribute, setting or similar prevents copying?
Or is there any other way to move leafs within the structure?
many thanks upfront
BR Simon
The following error message was unfortunately not coming up in front end but in the logs it says:
The string "Outerdiameter" used in the Autonaming Rule does not match the internal name of any attribute on this node, or the string does not match the 'CSM_NODE_NAME' constant for Node's internal name.
So the solution for me is to delete the autonaming rule, do the copy, paste and setup of autonaming rule again.
If I read the message it is a pitty because if the copy procedure would have another sequence, I would assume it would work without the workaround.
Perhaps this could be a bugfix?! 😉
cheers
cheers
