Hello Everyone,
I am working on a project and I need some parts to be added to a folder.
I have an assembly which has multiple parts associated with it. I want to add all of them in the New Project folder. But I want to simply copy them and not MOVE them.
SO basically I need to select all objects and create a copy in Windchill. Can anyone assist me in this.?
Thanks in ADVANCE.😊
Pankaj
Hi Pankaj,
You can select the assembly and perform the SaveAs operation,
In the collector window you can collect needed dependents, also set the new location of objects should be in
Hope this helps
Vishwas
Hi Pankaj,
Hope this helps
Vishwas
