Could anybody tell me the following packages in which JAR file?
kshu
2-Explorer
Could anybody tell me the following packages in which JAR file? I'm using Windchill 10.1 M050. Thanks a lot!
com.ptc.windchill.enterprise.doc.*
com.ptc.windchill.option.model.*
com.ptc.windchill.option.service.*
com.ptc.wpcfg.deliverables.*
10 REPLIES 10
KD
(To:kshu)
Based on the module installed typically you will find your packages in below jars.
DocumentStrutureBrowser.jar
DocumentManagement.jar
wncWeb.jar
OptionsCore.jar
wnc.jar
OptionsMigrators-windu.jar
OptionsMigrators-winru.jar
DDLBasic.jar
kshu
2-Explorer
(To:KD)
Thanks very much!
BineshKumar1
(To:kshu)
You can use the Which command to find out the resource jar for any class or package. From a Windchill shell, run the command java wt.util.jmx.Which
Thank you,
Binesh Kumar
kshu
2-Explorer
(To:BineshKumar1)
Thank you!
habat
(To:kshu)
Kouryo - As underlined by Binesh, you can use "Which" utility from a Windchill shell with "java" or "windchill" using "/" (instead of .) in order to separate the various java packages
kshu
2-Explorer
(To:habat)
Thank you!
ddemay
7-Bedrock
(To:kshu)
Be careful what jar file you use, packages are split among multiple jar files. Therefore, it is best to use an IDE like Eclipse to add all jars to a project classpath and use the java search features to locate where a class, method, or other information is stored (and to do this from full/maintence release/CPS to later)  and recompile as needful.
kshu
2-Explorer
(To:ddemay)
Thank you!
jessh
(To:ddemay)
Note that if Which tells you a given class is found only in codebase and you don't want to have codebase in your compilation classpath (or can't), then you can either:
  1. Create a jar from all classes in codebase (e.g. via a short Ant script) or
  2. Find the appropriate jar under WT_HOME/srclib to add to your classpath, e.g. srclib/wnc/Foundation.jar
You can use Which to help in #2, but it's not especially simple or easy.  You can append WT_HOME/srclib/wnc/* (using the "*" wildcard, not listing all the jars) to your shell's classpath and then run Which to search jars in WT_HOME/srclib/wnc in addition to those in the usual server classpath.  Unfortunately, you can't just add WT_HOME/srclib/*/* to your shell's classpath.  If this is a common stumbling block then perhaps an enhancement request to Which is in order.
ybagul
(To:kshu)
for Windows OS, following command works.
forfiles /S /M *.jar /C "cmd /c jar -tvf @file | findstr /C:"myClass" && echo @path"
