Create Cad Document
cadjett
Create Cad Document
Hello ALL, Long time, no chat.
I have ran into a situation, where a ptc training video, along with ptc support says there should be a "Create CAD Document" checkbox displayed on the New Wtpart page.
But in my current contract environment, it does not show.
Only 1 real ptc search page shows that you cant change a preference to hide the check box, but you can change the PartAttributes jsp page & either set change the true to false or vice versa.
Of remark/remove whole block on checkbox.
Has anybody ran into this. It showed to have been offered 1st in 10.0 & all version after.
PTC said there might be a customization on our installs, but the 3rd party services firm, didnt do much customizations & I dont think they would adjust a jsp to remove functionality without the windchill agreeing to it.
So can people look & respond on whether it shows for you.
Or has anybody ran into this & found the resolution. I am new here, so I dont have access to the box to view the jsp....yet.
Basically they want to create structures from the wtpart side & only the fly, have one, some be able to create an empty epmdoc cad (start part), while creating children of a wtpart structure. Some with cad, some with wtdoc, etc. Some blank for bulk items.
There doesnt seem to be an option on create a wtdoc (same as cad), but I might try to write something, where it uses a empty word doc, pdf (other wtdocs).
If anybody did that such thing & has code, I (along with others) would appreciate a copy.
But the main thing is to see if everybody else can see the "Create CAD Document" check box on the wtpart creation page.
PTC says its ootb, but who knows. they are still on the call, checking for a reason, but I assume they will say there is likely a customization which hides it.
Any help is appreciated.
Larry Jett
datajett@aol.com
11 REPLIES 11
"Create CAD Document" checkbox shows for me. Windchill 10.2 M10.
ddemay
7-Bedrock
(To:cadjett)
Check the profiles and configurations of the wizard screens in the type and
attribute manager...enable log4j verbosities that show if the box is being
conditionally hidden
On Sun, Mar 29, 2015 at 2:56 AM, Lawrence Jett <->
> all version after.
> wtdocs).
> appreciate a copy.
> hides it.
> Thanks
> Larry Jett
> datajett@aol.com
Check if you already have CAD Templates created at Product/org/site level
Best Regards,
Amit Lonkar
cadjett
(To:cadjett)
Thanks Yogesh
it might be a version & datecode thing, because I seen a ptc page that shows it resolved in 10.1 M050 & IM on M040
But it showed is fixed on 10.2 M020. I think also 10.0 M050
So I am surprised it showed/worked on 10.2 M010. but thats good to know.
The odd part is that the issue wasnt resolved in all 10.X versions. Makes you think they work on all 3 versions (0,1,2)
all at same time & once they found it in one, they updated all in M050 & M020.
cadjett
(To:cadjett)
Thanks David, I will check the type & attribute manager in the morning (Monday).
Thanks all for responding over the weekend
Larry Jett
cadjett
(To:cadjett)
Thanls Amit
I will check "Check if you already have CAD Templates created at Product/org/site level" in the morning also.
Larry
ddemay
7-Bedrock
(To:cadjett)
Good point Amit made. See also if they are enabled.
cadjett
(To:cadjett)
It turned out that some one edited the jsp & changed a true to false.
As shown on ptc page: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS44021
We are changing it back. They had a defineItemAttributesWizStep.jsp-original with true in it,
so some one before me (2011) made that mod.
I hope it wasnt because it didnt work well in 10.1 M040, where that was reported in ptc.com knowledge base.
We shall see.
Thanks for all the feedback.
Larry Jett
ddemay
7-Bedrock
(To:cadjett)
Need better documentation and source control if unknown or forgotten
changes occur. Eeeek.
I never saw any problems using it with 10.1 M040.
cadjett
(To:cadjett)
Dave, you should see this place. Forget About It...Haha
Next quesion folks.
Its working now for single new part creation, but doesnt see to show or be avaiable for Multi Part Creation.
Where it pops a windows with 5 rows of newly part/wtpart numbered or not.
But doesnt seem to have a checkbox, option for create new cad.
My questions is. Is it supposed to? If so, I might have more hidden / edited code.
I appreciate all responses.
Larry Jett
cadjett
(To:cadjett)
PTC says there is no "Create CAD Document" from the Multi Part Wizard & logically it makes sense.
Because you would have a new page for every new cad doc, where you would have to enter the desired cad attributes.
Then again, the multi wtpart page has multiple rows with columns of attributes to check, fill in, etc.
They could likely just have another page with multiple rows with columns of attributes to check, fill in, etc.
But I guess there is not much we can do, til they add it in the future.
Or we write it ourselves....<wink>.
Larry Jett
