Sorry, my initial state is Open, to avoid the additional workflows
from instantiating on a Revise.
My issue is I don't want a user to Check it out at Open. Thought, I
might be able to take away Modify at Open that could prevent the
abilitiy to Check Out on create.
Steve D.
Quoting "Villanueva, Antonio" <->:
> When a document is first created, its state is In Work. There should be
> no need to change it. You can put a check before the robot if you do
> need it to see if its checked out and sync (wait) until is checked in.
> Careful also with the workflows in the initial state. I believe it you
> revise it or set the state back to the initial state, it will trigger
> another instance of the workflow.
