I am using Windchill Risk and Reliability 12 and I want to create a FMEA report with values of different systems of a projekt. Is this possible or can a report only include values from one system?
Hi @tkupfer
I believe that JasperReporting can help you to collect data from others system, but you need to know how to do so.
It is same as you use Cognos. That is BI system that collect data from different systems and can create reports.
Or you can write own code that collects data from all systems you need and report them together.
PetrH
Hi @tkupfer
PetrH
