We have a requirement as follows :
In the change notice creation process, we have the Define Implementation plan step. Here we have a Change Task called "Modify Affected Objects". We can attach WTParts to the task "Modify Affected Objects" as "Affected Objects" and then can submit the Change Notice.
Once the CN is submitted ,we need to validate the Affected Objects for some attributes and fetch the parts which fail the validation , then create a new Change Task and attach these failed parts as affected objects to the new task and the task must be attached to the CN
So to start with , we started with custom form processor that extends CreateChangeNoticeFormProcessor . In the "postProcess()" method how do we get the affected objects that are attached to ChangeTask ?
Let us know your inputs.
Srikanth
