Create new JSP Site/Link in every CAD Parts & get Promotion Request Approvers
dwallys
Hello Guys,
At first i want thank everyone for his effort and answers to help me with that kind of "problem".
First Point: What i want to generate is a new "Button/Link" under the "Tab History" in every CAD Part (see screenshot1). Do you have any idea how i can generate that kind of button and link it to the information from the second point?
Second Point: On that JSP should be shown the Routing/Process information from the last Promotion Request (see screenshot2) . Do you have any clue how i can get that Routing/Process information from the last Promotion Request into every CAD Part Page?
Best Regards
Daniel
dwallys
(To:dwallys)
Creating a new JSP Site is very easy but a little bit complicated explained in the customization guide. You have to make changes on 4 files.
- navigation-actions.xml
- navigation-actionsmodels.xml
- e.g. PartManagement-actionsmodels.xml (only for Part-Pages other actionsmodels are available as well)
- navigationRB.rbinfo
Navigation-actions.xml:
<objecttype name="part" class="wt.part.WTPart" resourceBundle="com.ptc.core.ui.navigationRB">
<action name="test" type = "part">
<command windowType="page" url="netmarkets/jsp/part/test.jsp" />
</action>
</objecttype>
Navigation-actionmodels.xml
<model name="Testing" resourceBundle="com.ptc.core.ui.navigationRB">
<description>Testing 3rd level nav menu</description>
<action name="test" type="part"/>
</model>
PartManagement-actionmodels.xml:
<!-- Part information page 3rd level nav menu bar -->
<model name="third_level_nav_part">
<action name="productStructure" type="object"/> <!-- Structure -->
<submodel name="general"/> <!-- General -->
<submodel name="relatedItems"/> <!-- Related Objects -->
<submodel name="history"/> <!-- History -->
<submodel name="collaboration"/> <!-- Collaboration -->
<submodel name="Testing"/> <!-- Testing -->
</model>
navigationRB.rbinfo:
object.Testing.description.value=Testing
object.Testing.description.comment=Used for the text on the General third level nav menu. The <U class=”mnemonic”> </U> tag should be put around the character that is the access key.
object.Testing.hotkey.value=t
object.Testing.hotkey.comment=Mnemonic for the General third level nav menu. This should be a character that matches the character surrounded by the <U class=”mnemonic”> </U> tag in the value line above.
object.Testing.hotkey.pseudo=false
part.test.description.value=Test
part.test.description.comment=Test
part.test.tooltip.value=Test
part.test.tooltip.comment=Test
At the at you have to re-compile it to a java class with resourcebuild.
